Hey guys, trying to get a Gottlieb Sounds & Speech Board working for a Black Hole I am repairing.
Symptoms: Game emits a very loud consistent "screach" tone as soon as the machine is booted (any time there is power applied to the board). The test button does nothing.
Diagnostics: I am getting pings on the sound select lines at the CPU board output, the S&S board input, through the invertor to the RIOT chip.
Benchtesting:
Replaced all the electrolytic caps.
I built a harness, and I have all 4 voltages hooked up, as well as a speaker. The board will power up and emit the same screach. I disconnect the speaker and put headphones on the pre-amp side of the amp (the middle lug of the volume pot) and I get nothing at all.
I've pull the 6502 and replaced it with one from another arcae board. I've tested the 6532 in my NeoLoch Tester, it tests fine, but I replaced it anyway since it was socketed.
I've ordered a replacement board from someone here on pinside, but I'd still like to get this one going since I know I am very close to getting it working.
