OK, now that vacation is over, here's the latest.
I have the jones plug set for a 3-ball game. The game ignores that and wants to play five balls. The ball count unit is resetting properly to the zero position and advances to ball 1 when the ball rolls over the right hand ball trough switch. It continues to advance properly from 2 to 3, 3 to 4, and 4 to 5. But sometimes it sticks on ball 5 for a couple of balls before advancing to the 6th position (game over position).
At the 6th position, a match (replay) light comes on but the game over lamp never lights. Good bulb.
The three switches on the back of the ball count unit are set as follows. Zero position: left switch closed, middle and right switches open. 1 through 5 positions: all 3 closed. 6th position: left open, middle and right closed.
The plunger on the advance coil of the ball count unit goes all the way in and out at positions zero through four. At 5th position, the plunger does not retract all the way. When the plunger is pulled manually out of the coil, the stepper advances to 6th position, but the game over lamp still does not light.
Basically my three problems are: no 3-ball game, no game over lamp, and lack of advancement to the 6th position. Frankly, I'd like to try and fix the first two before I have to tear the ball count unit apart and clean it . It does seem like it's gummed up.
Thanks for your help guys.
Alan
