GTB Raven Help Needed
By Cherga
4 days ago
Stats
  • 5 posts
  • 2 Pinsiders participating
  • Latest reply 11 hours ago by Cherga
Find
Search this topic for posts matching certain words or written by a specific Pinsider. Or both!
#1 4 days ago
Hi all, I have an issue with my Raven machine. When starting a game the drop targets all drop as they should however the upper and lower target bulbs go out and never activate during a game. The upper and lower right drop targets work fine. Any ideas on what this can be? Thanks!
#2 3 days ago
Hi,
On the Raven, the targets banks are a bit special : indeed there is no traditional "banks" implemented like walls, but four individuals targets acting more like gates (rollover targets). So, there is four "single target" banks. As usual, a target bank can be reset (target raised), but also trip (target downed). The reset function is made using a "big" coil (A-18102) and the drop function is made using a small "flat" coil (A-19508, located inside the bank).
As usual , as there is not enough outputs on the driver board, the main coils (A-18102) are driven by SOLENOID outputs (#1, #2, #5 and #6). While the little coils (A-19508) are driven by lamps outputs (L12, L13, L14 and L15).
This is the schematic :
As the drop function works on all banks, this means that the L12...L15 outputs works fine, but also that the fuses F10 and F11 are OK.
As the issue is only on the left side, the culprit should be SOLENOID #1 and #5, that are not working.
But first : check if your Raven wiring is original (because, sometimes people add extra-fuses on coils lines).
May be, this is only a bad contact problem. Check the A3J4 (on the driver board), try to plug/unplug it (of course, with power off !).
The worst case, the driver board is defective (and no more drive SOL #1 and SOL #5). In this case, probably the 2N3055 (Q58 & Q62) are burned.
If you have a spare driver board, try a swap.
#3 3 days ago
@noflip95 thank you very much for the very detailed help! The first things I checked were connections and found a shorted wire. Now all targets fire randomly however I want to confirm operation since I just got the machine.
At game start all targets drop and lights go out. Randomly during play they’ll pop up and the light turns on for the activated target. After hitting the target and dropping it, the light stays on.
Does that sound like proper operation? Thanks!
#4 1 day ago
Quoted from Cherga:
Yes
◾At the game start, the four "snippers" goes down.
◾During game, when the snipper sequence is activated, the "snippers" appears and disappears randomly.
◾At the end of the game, the four "snippers" goes up (and thus are all visible while the attract mode).
→ During the snipper sequence, only one "snipper" target is raised at a time, and remain active for some seconds, then it is retracted. When the "snipper" is up, the orange triangle light in front will flash. Hitting a "snipper" award 50.000 points, and the orange light remain lighted (to indicate that this snipper has already been hit).
→ To activate the snipper sequence, this depend of the selection of the DIP switch 31 (easy/difficult), either :
↠ complete the bottom left or right, 3 targets bank (in easy mode)
↠ complete the bottom 6 targets bank (in difficult mode)
The hit targets have their white triangle light off (otherwise, it is flashing)
→ For the SPECIAL, this depend of the selection of the DIP switch 32 (easy/difficult), either :
↠ shoot 3 "snippers" (in easy mode)
↠ shoot 4 "snippers" (in difficult mode)
Note also, that the TEST mode on SYS80B is "intelligent" :
- as the lamps L12...L15 are used for coils, they are not tested during the lamp test.
- but, during the solenoids test, they are activated and also the SOL #1, #2, #5, #6.
This allows to see the all 4 snipper targets to move up/down.
#5 11 hours ago
Thanks again for the help. I have a new issue I’m chasing... I can’t get up the ramp. A-20095 coils are good but the ball only makes it half way up the ramp. It doesn’t look like the field upgrade to reduce stress on the Eos switches was done on this machine. Could that be the issue? Thanks.
€ 50.00
FLIPPROJETS
€ 40.00
FLIPPROJETS
€ 8.40
$ 40.00
Great American Pinball
$ 229.99
$ 42.99
Lee's Parts
$ 9.99
$ 48.00
$ 29.95
$ 48.00
$ 1,089.00
$ 69.99
$ 29.99
$ 5.00
Wanna join the discussion? Sign up for a Pinside account, or log in if you already have an account.
