(Topic ID: 194544)
GTB North Star Score Motor/Relay Bank Issue?
By spiroagnew
6 years ago
#1 6 years ago
Intermittent problem on my North Star finally became mittent (?). Blessing, as it can now be fixed permanently, right?
Score reels reset to zero. But score motor runs indefinitely. One relay bank indefinitely fires while the score motor runs. The second relay bank, which houses the start relay refuses to fire at all. Coil and fuse check good. Previously, if I just waited, the game would finally "catch", drop the balls and start a game after the score motor and the relay bank fired a handful of times.
I found that if I activate that second relay bank coil manually, the balls will drop, and a game will start. Everything will score in this state except the two bottom rollovers near the flippers. Game will never reach game over though.
Excerpts of the schematic can be posted post haste. I need a little help with the logic of following the circuit and which contact to check.
Thanks in advance EM folks.
#2 6 years ago
Here's the circuit that resets your relay banks. Be very careful and you should probably unplug the machine while working on it because this circuit runs on the full 120 volt line.
#3 6 years ago
Thanks to Howard, I found the NC switch on DB that wasn't making. It now closes properly and was probably the switch that was flaky all along.
But now, when I push the replay button to start a game, the SB start relay engages, but nothing else happens.  If I manually turn the score motor the game starts and plays fine.
#4 6 years ago
Here's the circuit that runs the motor, along with the switches most likely out of adjustment.
#5 6 years ago
Right again, Howard. Make/Break on SB wasn't making the proper connection. When pressing down on the SB actuator after it was engaged it would make the contact, and start a game...one a minor adjustment set it right. North Star is happy again.
Big thanks to HowardR
Cabinet Parts
Space Coast Pinball
This page was printed from https://pinside.com/pinball/forum/topic/gtb-north-star-score-motorrelay-bank-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
