(Topic ID: 215711)
GTB King Pin Lights Question
By goldenboy232
1 year ago
  • 4 posts
  • 3 Pinsiders participating
  • Latest reply 1 year ago by goldenboy232
#1 1 year ago
On the King Pin I just finished restoring, I have a question about the left and right return-Lane lights. See photo.
Should these light for 500 hundred points only after the drop targets are all down the first time? Or should they come on occasionally for 500 points through other game play? Mine only turn on after all the drop targets are down to then give me the option for 500 points via these rollovers.
It also affects the lights under the two white inserts near the top of the playfield that also score 100/500 when lit.
I can’t tell for sure by how the schematic is labeled which are which. Are the ones at the bottom the left return and right return rollovers? And the ones at the top the left outside and ride outside? I think so.
If I’m reading the schematic right, the left and right return rollover lights are actuated by a normally open switch on G through motor 4D. And it looks like G would only actuate after the sequence is completed, and the E relay pulls in. So I’m thinking those two white lights in the return lanes only come on after the Target bank is down the first time.
However, the top two wines, presumably, our “left outside rollover light“ and “right outside wall or liked”. If that’s the case, those should be coming on and off through a make/break on cue relay during the game, and I don’t see that happening.
Here’s also a picture of that part of the schematic. Would appreciate help.
#2 1 year ago
Quoted from goldenboy232:
That's the way it works on my King Pin (which was beautifully restored by NicoVolt). I was surprised it worked that way as well.
#3 1 year ago
Left return lane and right return lane are the lanes by the flippers that send the ball in front of the flippers.
Q relay is the alternating relay. If the left outside rollover light and right outside rollover light are not working or not turning on and off, check the following:
Q relay switches - make sure the switches are clean and adjusted properly
F relay switch - red/white wire and yellow/green wire - make sure the switch is clean and adjusted properly
Light sockets - confirm light sockets are making proper contact with light bulbs
#4 1 year ago
Quoted from fredsmythson:
Thanks Fred, they do work, my question was more about if they’re working at the right times. The response above yours seems to indicate that mine are working correctly.
$ 279.95
$ 279.95
$ 279.95
$ 279.95
$ 399.95
€ 45.00
YOYOKOPTER MODS
Metal-Mods
$ 53.00
$ 19.95
Playfield - Plastics
Mod Magic!
$ 19.95
