Thanks for looking......
Gtb Jacks Open. Hasn't been played for a while and I had a few games the other day only to find that the drops were struggling to drop fully and reset. Pulled them apart and cleaned everything up, they were a bit grotty and due for a clean. Now for the life of me, I can't get the targets to reset if they are all down. Adjusted contacts so there absolutely minimum resistance from them to raise the drops, played around with adjusting the coils to try to get as much plunger in the coil as possible whilst allowing full range of movement. It just seems that when the playfield is down, there is not enough strength in the reset coil/s to fire the drops up far enough for them to clip in place. The machine tries to do it repeatedly but the drops aren't lifting up far enough to reset.
The only thing I haven't done is put new coil sleeves in the drop reset coils.
The machine plays fine until it gets to a point where all drops are down. It follows the sequences fine, scores 99% of the time (I need to clean contacts as well). If one or two drops are up, the rest will reset no worries at all. It seems the added weight or resistance of the internal reset bar is just too much for it. If the playfield is up, they will more than likely reset, put the playfield down so gravity comes in to play as well and no joy.
As far as I am aware, coils are either good or bad. Both tested OK as far as Ohms go. There is no physical resistance to the plunger, they both move and slide freely in and out of the coil/s. The royal flush drop sequence works as it should.
Has anyone else encountered this and if so, what ended up solving the problem? As mentioned, the only thing I haven't done as I am thinking as I type are the coil sleeves. Other than that, I am about at my wits end.
