I'm having trouble with the credit wheel on my El Dorado. This is the half circle window which is also used on Abra Ca Dabra. It gives credits like its suppose to and lights the wheel when it gives credit. The problem is when I reset the game it dosent take a credit away. I mimicked the set up as my ACD. I do have the contacts on inside switch touching putting it in freeplay. I took part of it apart tonight a cleaned it. I manually put it back on 0. When resting at 0 all the switches are open except the inside ones I moved close for freeplay. Any thought what I'm doing wrong? Thank you for any help
