(Topic ID: 326146)
GTB Dimension Extra ball on points issue
By DropTarget
1 year ago
#1 1 year ago
Hi All,
I noticed on my Dimension that the machine does not reward extra balls for points (sort of).
Here's the sort of part.....It will add a ball for scoring if the 10,000 reel rolls over via a pop bumper hit but not if rolled over by a 3000pt or 500pt switch.
The difference is that when scoring the 3000 or 500 points, the score motor rotates, while rolling over from a 1000 pt pop bumper hit, it does not.
The machine counts up to 5 balls easily on start up, and adds extra balls when the Wow targets are hit. The C relay (add ball count unit relay) works well, if triggered manually, the knocker knocks and a ball is added, when scoring from the 3000 and 500 pt switched, the C relay pulls in, the knocker coil fires, but the ball count unit does not step up.
Signed confused in NJ
#2 1 year ago
You could experiment by wiring a 2nd Score Reel to the 10k Score Reel. Just jumper the Score Reel coil solder lugs together for the two lugs that are not connected to a black wire. Use the 10s or 100s Score Reel.
If the added Score Reel advances correctly the issue is likely a mechanical issue with the 10k Score Reel. If the added Score Reel behaves the same way as the 10k Score Reel the issue is likely in the circuit driving the 10k Score Reel.
/Mark
#3 1 year ago
Thanks Mark,
I've just noticed that the score motor does not always home. there are times when it stops and the kickoff hole won't eject until I rotate the score motor.
#4 1 year ago
although when the ball doesn't eject, the other score motor functions do work.
related???
#5 1 year ago
Quoted from MarkG:
Jumped to the 100's reel, they both advance correctly, that was never the problem. They problem is that the machine doesn't step up the ball count unit when the points are made (30,000 & 60,0000 in this case) unless the score motor is not running. When the score motor runs, as in when a 3000pt or 500pt pf switch is made, the knocker knocks, but the ball count unit doesn't step up. If it rolls from 29,000 for example to 30,000 via a thousand when lit hit on the pop bumper or from 29,990 and a 10pt sling switch is hit, the ball is added (the score motor does not run in those instances)
#6 1 year ago
also, If I jump O-B to B-W on Motor 1C (the blades are next to each other), the step up coil pulls in, and advance when I disconnect the jumper. They appear to be making good contact, unfortunately, my wife drove off with my tools in the car, so I can't check if they're making good contact with a meter, or squeeze the points. yup, blame it on the wife.
#7 1 year ago
Sorry, wrong problem.
It's odd that the Knocker works but the Ball Count sometimes doesn't. They're essentially wired in parallel. I wonder if it's getting a short pulse that's not long enough to advance the Ball Count.
One switch that comes into play when the motor turns is the 1C switch in red below.
Dimension Add Ball Count (resized).jpgDimension Add Ball Count (resized).jpg
See if the normally open side of that Make/Break switch is operating correctly. Also check if the On Add Ball Count Unit (EOS) switch is opening too soon.
#8 1 year ago
Quoted from MarkG:
Exactly, I've been thinking its a timing issue, but haven't figured it out yet. So, what's different in that circuit if the score motor is moving?
I can almost breath on the C relay and it adds a ball.
#9 1 year ago
That make or break is where I've been focusing, but I can't find anything obvious. If I understand it, when the motor is not moving, the path goes through the N.C. side, and when the motor moves, the path is through the N.O. side. Maybe it's time to trace that wire, or jump from the switch to the ball count unit, could it be a jones plug going to the head?
#10 1 year ago
AHHA!
Well perhaps AHHA!
#11 1 year ago
Quoted from DropTarget:
Well perhaps AHHA!
Yup, that was the problem. Broken blade.
#12 1 year ago
Good eye
Earlier this year I did a full rebuild of Abra ca Dabra, I found a few broken contact blades. The transformer was set to regular tap, still is. What causes switch blades to break?
#13 1 year ago
Quoted from BRONX:
Aside from abusive people? IDK
This page was printed from https://pinside.com/pinball/forum/topic/gtb-dimension-extra-ball-on-points-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
