Hi pinsiders
do You know the logic in "Gottlieb Central Park" ?
Can You tell me about the "1-3-5" "6-8-10" mystery (mystery to me) ?
Here: http://www.ipdb.org/showpic.pl?id=481&picno=9703&zoom=1 I can make single "1" and/or single "2" and/or ... "10", on top of the playfield.
When I loose a ball it will go either through "1-3-5" or "6-8-10" (near the flippers) - lets say "1-3-5", NOW, am I given
"1" and "3" and "5" plus 30 points - and the result is exactly the same as " I would hit "single-1, "single-3", single-5, I make (in some kind of a way) 30 points and by hand: put the ball behind, loosing it ?
OR: when I loose the ball through that "1-3-5" - am I given just ONE of them (if "single-1" is not yet hit: I get the "1" etc.) and I get 30 points.
The same question to the (left and right) Side-Lanes, (also) marked "1-3-5-and-30-points" / "6-8-10-and-30-points.
Can You tell me about ? (I am trying to help in a German forum, we have the schema (but no manual) - I had a look in the schema - but do not fully understand it)
Here: https://pinside.com/pinball/forum/topic/em-tech-1966-gottlieb-central-park#post-2111668 - the problem is similar. I had a look in the schema - I see the P-Delay-Relay but have problems to understand.
WHEN I loose the ball through a "Bottom 1-3-5 or 4-6-10": The P-Relay is involved.
IF I shoot the ball through (middle lanes) "1-3-5" or "6-8-10": The P-Relay is NOT involved (((why?))).
When the P-Relay pulls -> it opens a Switch***.
I do not see, how pulses (SCM-1A) can reach "No-1-Relay / No-3-Relay / No-5-Relay" - the Switch*** IS OPEN. (Well, I look in a "not so good copy of the schema" - maybe I miss something ...)
Greetings Rolf
