Quoted from Batcade:Thanks for the info, I guess what I am really need to know is where to put the DMM probes to test the power A2 board to see if correct voltage is getting there.
The schematics show "TP" or Test Points on the circuit board. When you look at the power board you should be able to find these, typically as either wire loops (for if you have clip on DMM probes), or in my case for Spiderman, little posts. They are clearly marked on the circuit board as well, indicating which voltage is at that test point.
Connect the "Common" probe of your DMM to the Ground Test Point, and the other probe to the test point.
Ensure you have the correct setting on your DMM, AC voltage or DC voltage, and a level that is the next one higher than the voltage you are testing (ie. setting 20V DC for signals that are 5V and 12V.... or setting 100V for signals that are 24V, 48V, 60V...)
When you are on the bottom board in the pinball box, there are no "Test Points", but everything is pretty clearly labeled (like on the fuses, and around the diode bridges), that you can use as test points. On the bottom board, there is a long strip of metal with lots of green wires attached to it... that is one of your main Ground connections. If you're probes don't have clips, it would be a good investment to buy a pack of wires with alligator clips on them. Put a clip on your Common probe, and clip the other end to a ground point. Then you only need to probe around with one, instead of trying to hold two probes on two places.
I expect you will quickly find that you have no 12V on that board, since the 12V and 5V LED's are off. Then you will need to probe in the bottom of the pinball machine where the transformers and fuses are to see if that's all working.
Apologies if I'm being too simple in my directions... not sure what level of experience you have, but since you're asking about where to put the probes, I'm assuming it's limited. Just let me know if I don't need to be that detailed for you and what you already know how to do.
Again, you'll have a hard time figuring things out if you don't have a wiring schematic. Let me know if you have them from a copy of the manual, or if you want me to send you a copy to print off.
Happy New Year!
