Just about completed a full resto of this machine but stuck on a 3rd chute issue-advice sought.
This machine has 3 coin chutes; no 1st/2nd chute adj plug but a 3rd chute adj plug 0-5plays. The coin switches on chutes 1 & 2 share the same blue wire to the coin door jones plug. Initially switches on all 3 chutes would not activate play/replay.
Chutes 1 & 2 now resolved by reversing a hack.
However when chute 3 switch is activated it just energises W (extra chute) relay but does not add replays. Quite separately if I manually energise R hold relay chute 3 switch will energise W & add replays.
I have reviewed the chute 3 path from the schematics & as best I can confirmed all contacts ok. I would appreciate any advice/clarification on the normal Gottlieb path between a W relay & the add replay function on a credit unit. Thks Wayne
