(Topic ID: 244808)
GTB 1965 Skyline-cab repaint notes
By wayner
11 days ago
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 4 days ago by goldenboy232
There have been 34 images uploaded to this topic. (View topic image gallery).
#1 11 days ago
In the past I have documented a number of restos which included cab repaints. While I certainly prefer the original patina at times it may be so dilapidated or emasculated by poor touch ups that a repaint is necessary. That was the case with this Skyline. The cab front was fairly typical of the cab condition.
My preferred stencil approach is to avoid adhesive stencils because generally they do not allow the spray bleed as per the original manufacturing process. Now that process used metal re-usable stencils but of course without the home equipment that for most of us is not available. I have therefore typically used mdf board for the stencils after first taking a graphics trace , transferring the trace to the mdf then cutting the stencil with a jigsaw-I use a fine tooth metal blade as it provides a nice fine cut and importantly does not rip the reverse side of the mdf. This is important as each re-usable stencil is used for both sides of the cab (except the fronts of course).
I wanted to specifically cover my approach to Skyline because the graphics include multiple continuous blue vertical and horizontal borders. For these borders my traditional mdf approach was not possible so I decided to fabricate blue border stencils using moulding from the local hardware store. All up the mdf for the red and non border blues and the moulding cost about $70. This compares to purchase of a retail stencil kit which with exchange rate and shipping would for me cost somewhere towards $A450.
These are pics covering some of the process:
-initial tsf of trace to mdf
-after jigsaw cutout and registration check with original graphics
-registration check for backbox blue horizontal borders
-cab primed
-cab base coat
Unfortunately I did not take a pic of the webbing application prior to graphics application but will appear in finished pics.
-spray process
Once the stencils have been fabricated and before removing cab paint I double check each stencil registration with the original cab graphics.Then cab paint is removed and structural/cosmetic cab issues addressed. The paint on this machine comprises white primer, base coat, webbing, red panels, blue border verticals and blue border horizontals. Examination of the original paint indicated the factory had sprayed the vertical and horizontal borders separately.
These are the spray guns I use:
-a high volume low pressure gravity feed gun (inexpensive) for the base coat
-a high pressure touch up gun (inexpensive) for the primer, webbing and general graphics
-a Badger Anmthem 155 airbrush (not an el-cheapo) for the fine work; in this case the blue borders
These are the stencils after use:
-backbox front and red squares
-backbox blue vertical and horizontal borders
-cab front and red squares
-cab front blue vertical and horizontal borders
-cab sides blue vertical and horizontal borders
These are the finished pics:
Overall I am happy with result and hope the process is of value to other pinsiders. I will post further pics when the complete resto is finished.
#2 11 days ago
Great job!!! I just finish a cabinet with poster board as the stencil. It worked but I’d much rather do what you did here.
#3 11 days ago
Quoted from mrm_4:
Thanks. You know its a funny thing I am not a tradesman but I prefer using a jigsaw to an exacto or retractable blade knife which is probably why I have used mdf.
#4 11 days ago
Impressive work as always, Wayne! Question: how do you transfer the trace onto the MDF board in the first place? I’ve never figured out that step. I’ve always only used the “Pinball Pimp” stencils, which turned out great, but may want to try this at some point.
#5 11 days ago
Quoted from goldenboy232:
Use the trace as a cutting guide. When transferring to posterboard its straight forward cut thru with a sharp box cutter.
#6 11 days ago
Here's my stencil kit for Buckaroo, Kings & Queens, Cowpoke etc. I like the heavy oil board as my stencil, cuttable with a box cutter. I then weigh it down with MDF. Ive done a dozen checkerboard games with this kit.
It gives it a nice touch of factory fuzzy as shown with the KoD diamond I did with the oil board.
#7 11 days ago
Thks Mark. I cut the tracing paper to create the outline for transfer to the mdf board. This is an example on the orange colour re my Double play. Best rgds Wayne
#8 4 days ago
Quoted from pinhead52:
Ken how do you keep the tracing paper from crumpling up as you cut through it, messing up the accuracy of the cut?
$ 279.95
850
Vacaville, CALIFORNIA
$ 279.95
$ 279.95
$ 279.95
$ 399.95
$ 48.00
$ 159.99
CzTV Mods
$ 129.95
Hookedonpinball.com
