(Topic ID: 299820)
Grounding Gottlieb Sing Along
By Sewellmatts
51 days ago
  • 6 posts
  • 5 Pinsiders participating
  • Latest reply 46 days ago by Sewellmatts
#1 51 days ago
Newbie. If I understand from reading--the ground wire should be connected to the frame of the transformer. Please confirm. Advice and help is requested.
#2 51 days ago
Remember that Sing Along was issued with a two prong plug, so adding the ground is an after market thing. However, I agree with its use.
I would put the ground to the transformer case. I think Vid has a guide on here about grounding and adding a new cord. Do a search for Vid’s guides. There’s lots of them out there.
#3 51 days ago
Yes, and to the ground braid that runs throughout the machine. If your game doesn't have ground braid here is a post about adding it: https://pinside.com/pinball/forum/topic/replacing-line-cords-plugs-wall-sockets-vids-guide#post-1945124
https://www.pinballlife.com/flat-tinned-copper-ground-braid-5-feet.html
#4 48 days ago
Grounding to the transformer base alone does absolutely nothing!
#5 48 days ago
I'd ground the coin door and I'd make sure that the plug is polarized correctly.
#6 46 days ago
Thanks to all. I will follow the procedure referenced by YeOldPinPlayer as best I can.
