(Topic ID: 233911)
ground row short back again
By DUKE_WADD
5 years ago
  • 14 posts
  • 6 Pinsiders participating
  • Latest reply 5 years ago by DUKE_WADD
#1 5 years ago
had a ground row short error on a buddys shadow game a couple months ago checked all switch row and couldn't find a short to ground, finally ended up changing u 20 and u 23 after waiting foever for parts then getting sent the wrong parts anyway 3-4 months later stared the game fine no errors. played for about 4 day and the same error is back.
whats causing this ?
what should i be checking next ?
#2 5 years ago
Did you socket u20 and U23?
Do you have a chip tester?
I would pull and test the chips to see if they are bad.
#3 5 years ago
ya both are socketed
havent even looked at it yet but at least one of those chips will be bad now
have extra chips but dont wanna put them in until i figure out why they keep blowing
got about 30+ games before it happened. buddy said he thinks it happened both times when the ball was on the battlefield.
#4 5 years ago
I had a sorcerer that was feeding coil voltage to the switch matrix. One of the pop bumpers had a partial coil wrapper and the motion wore through the wire insulation and set coil voltage to the switch.
I found it by putting the game into play and touching each bracket with a dmm lead. If any bracket is showing voltage this could be the issue
#5 5 years ago
Quoted from Cheddar:
good idea i will try that see what i can find
#6 5 years ago
found this under the mini playfield rubbing on the metal under it but it goes to a light.
#7 5 years ago
A light shorting to a switch will cause u20 to go bad.
I think you are close to the issue, under the Battlefield somewhere.
#8 5 years ago
well worked on it today for a bit fixed the wire with nicks in it, checked all solenoid brackets couldnt find anything changed u23 again cuz it was fuct turned it on and ground row short row 1 stuck closed. cant get in menu or do anything
-read it could be opto board so unpluged it the error went away and could get in meun
-menu said ground row short 3,6,7 or somthing
stuck on what to do next
#9 5 years ago
Quoted from DUKE_WADD:
Replace chip. I had this same problem I'm pretty sure a while back. It was a bad chip.
#10 5 years ago
I had gotten some chips which were counterfeit. So be sure of where you buy chips from.
#11 5 years ago
Does your friend have another machine with a 10 opto board that he could swap in?
#12 5 years ago
chips from marco so pretty sure there good think u20 is done again and no more extras
no other machine to test parts from
another thing when you turn it on a few of solenoids fire 3-4 times before they stop
#13 5 years ago
Those solenoids are probably associated with an opto, assuming the opto board is still unplugged.
#14 5 years ago
Quoted from alveolus:
opto board was pluged in when solenoids were popping
$ 69.50
Trade
Machine - For Trade
Aurora, IL
5,200
Buffalo, NY
$ 78.50
€ 38.00
PPmods
€ 8.50
Pin-Decals
YouBentMyWookie
$ 16.00
Slap Save Creations
Louisville, KY
$ 329.99
$ 49.99
$ 29.50
Playfield - Plastics
$ 58.00
Pinball Mod Co.
5,000
$ 65.00
$ 9.95
€ 8.50
Pin-Decals
Arcade Upkeep
$ 43.00
Pinball Mod Co.
€ 47.00
PPmods
Flashinstinct
€ 47.00
PPmods
$ 45.00
Pinball Mod Co.
$ 54.95
$ 5.00
$ 259.99
This page was printed from https://pinside.com/pinball/forum/topic/ground-row-short-back-again and we tried optimising it for printing. Some page elements may have been deliberately hidden.
