(Topic ID: 309046)
Gridiron help.
By Jon9508
2 years ago
  • 24 posts
  • 5 Pinsiders participating
  • Latest reply 2 years ago by Garrett
    #1 2 years ago
    Wow first off let me say ems are a different animal. I would rather work on a mpu/driver board. So i have this gridiron. It won't start a game with the ball in the trough hole. Once I pull the ball out. The flippers and all of the mechs work and score. When I let the ball drain it doesn't end the ball and start the next ball. When the ball sits in the drain hole the stepper unit just spins and never stops and lights flash. Not sure what relays controls what. I did take the time today and clean every contact and adjust the switches. Any help would be much appreciated. Can't seem to find a manual online. Guess I will have to buy one from pbr or marcos.
    #2 2 years ago
    When its trying to reset, are all of the score reels at the zero position, does the ball count reset to ball 1 and does bottom most football insert lite?
    #3 2 years ago
    Yes. All score reels are at zero. Ball is at 1. Football is on the first one. Just went back and looked at all of the reels. Bottom switch is closed on them when at zero. They seem to be all making contact.
    #4 2 years ago
    I just picked one of these up today. Will be watching this thread.
    #5 2 years ago
    I am more familiar with pro football. The ball is kicked into the playfield by hitting the right flipper button. I think the first issue is to determine why the game resets the reels, player and ball position, but will not kick out the 1st ball.
    #6 2 years ago
    The right flipper button does not launch the ball into the playfield? Has the K relay pulled in?
    You have a schematic?
    #7 2 years ago
    When the ball is in the hole the lights flash. Like when the varie targets are hit. No I can't launch the ball with the right flipper. Power is killed to all of the coils until I physically remove the ball from the hole.
    #8 2 years ago
    Can you tell which switch is powering the motor (see schematic)? One way might be to (with the playfield up) close the ball return switch manually and see which relays are pulling in... or use slips of paper in the switches to block each switch until you find the one that is making the motor run.
    Sorry for the quality of the schematic (and ignore the markings), I only have a few disjoint snippets...
    #9 2 years ago
    Quoted from DaMoib:
    Sorry for the quality of the schematic (and ignore the markings), I only have a few disjoint snippets...[quoted image]
    I will look at it in a few. I am guessing that's the score motor(one in the cab) yea it runs nonstop while trying to reset.
    #10 2 years ago
    Looks like I am going to have to buy a schematic from marcos. When the ball is tripping the out hole switch. The player motor , the score motor both run. And the lights on the upper playfield flash. Take the ball out. I can flip the right flipper. Left seems to be dead now also one of the chimes isn't trigging now. As far as the relays pulling in. Game over pulls, 1st ball pulls in. I just got done. Pulling every switch and the score motor and reinstalling. All adjusted and cleaned. Also went back over the relays in the bottom. Makes sure they were all adjusted correctly and contacts cleaned. After 3 hours decided that was enough for today. Nothing changed.
    #11 2 years ago
    I wouldn't recommend wholesale cleaning and adjusting of switches, you're likely to cause more issues than you solve.
    Definitely get a schematic.
    By "player motor", you mean the Player Unit in the backbox? Is the "Ball in Play" continuously changing and going on/off?
    #12 2 years ago
    Quoted from DaMoib:
    Yes both the player and the score motors are going.
    #13 2 years ago
    Check the P3B switch, riding on the middle cam of the Player Unit, the PU should stop at Player 1, Ball 1 after reset - P3B should open.
    AND P3A should close, resetting the AX relay.
    Do you have a newer PU? I believe it may have 3 green cams. If so, the P3A and P3B switches are riding the 3rd cam, furthest away from the PU rotor.
    #14 2 years ago
    Quoted from DaMoib:
    +1 that. Tighten the stacks, but don't start adjusting anything till you work thru what works and what doesn't. The AS relay for moving the football up the PF is finicky SOB.
    Well @damoib, here you go again.....
    #15 2 years ago
    I tighten all of the stacks. Some were loose for sure. It's a shame I had to spend 35 dollars on a schematic, but it's coming. To much time wasted for me not to get but to work. Hope I can read it. Looks like a foreign language l.
    #16 2 years ago
    Quoted from Jon9508:
    $35? NOS is $16.50 from PBR.
    #17 2 years ago
    Quoted from tomdrum:
    Lol. Went with marcos. Pbr is a pain sometimes.
    #18 2 years ago
    Pain is weakness leaving your body. Look the game over, order all the parts it needs. Usually new flipper bats, pop bumper caps, rubber set, lamps, coin door decal, locks, leg levelers and anything else that looks suspect. I'd also upgrade the outer flippers to the yellow dot coils, big improvement in game play. Email the order to Jimmy. 2-3 days later, in your mailbox. Writing the check, and mailing it is worth the savings IMO.
    #19 2 years ago
    Also without PBR, Marco couldn't sell you that schematic. Support the company that is providing the parts, not the one just reselling them. Shopping carts are great, without PBR your cart is empty.
    #20 2 years ago
    I have ordered from him before. It's just a pain. Plus people have been posting the last few weeks that's he has been so busy not taking emails orders and having to call and hope he answers. Also I am pretty close to marcos. Usually get order the next day or 2 at the most.
    #21 2 years ago
    Without PBR, we might be able to download that schematic like you can for Williams and Bally games.
    #22 2 years ago
    #23 2 years ago
    The manual and schematics should be here today. Hopefully I will have time tonight to dive into it. Goals will be trying to figure out why when the ball is in the drain hole the game thinks the variy targets or triggering and kills the launch coil on the right flipper button. Then figure out why I don't have any flipper power of my left flippers.
    #24 2 years ago
    Sounds good. I'm still finishing up the playfield on mine but will keep an eye on this thread. Mine came with schematics so will be ale to follow along and help too.
    This page was printed from https://pinside.com/pinball/forum/topic/gridiron-help- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
