I picked up a non-working Granny and the Gators about a month ago and have been looking at it and trying to get it working since then. The game will not boot, when it turns on the game starts its self-tests and seems to complete them but shortly after the last flash on the vidiot deluxe board, there's a "click" that sounds like it comes from the boxed relay on the drive board and the LEDs on the idiot board and cheap squeak go off. There is a brief image that flashes on the display when this happens and then it goes blank (but appears to be on still, you can see the square backlight if I turn the lights down in my workshop) but no fuses are blowing so I don't believe it's something to do with the game shorting out... just not sure what exactly is going wrong. Here's what I've done so far:
When I first got it, the MPU looked pretty beat up and the battery connectors were gone. I ordered the Alltek Ultimate replacement board and installed that with the dis-switches all set properly for Granny and the Gators. This didn't solve the problem.
I noticed corrosion on the TMS9928 processors and the RAM at U29-U36 on the Vidiot Deluxe board, and since the video display isn't showing anything I was suspect of the video board. I replaced both processors and the RAM at U29-U36, but this did not solve the problem either.
I haven't been able to track down exactly where the "click" happens when the boot process stops, but it sounds like it might be on the boxed relay on the driver board. I'm not familiar with or able to track down any information on how that relay functions (feel free to point me in the right direction if you know!) so I'm unsure of how to test that or what it means if that is happening.
I'm hoping somebody with familiarity with this game could give me some suggestions on what to test to further to narrow down the issue and what's going wrong? I'm thinking of replacing the solenoid/driver board since there is also an Alltek replacement for that but since replacing the MPU didn't necessarily "help" anything, I'm hesitant to do that without reason? The solenoid/driver board is in better shape than the MPU was and I don't see any visible corrosion or places where it looks like it's gotten hot or damaged.
Thanks in advance for any help/pointer you can offer!
IMG_8342 (resized).jpgIMG_8345 (resized).jpgIMG_8347 (resized).jpgIMG_8348 (resized).jpg
