(Topic ID: 317977)
Grand Slam (1953) Flipper Links - Do I have to make them?
By HydrogenHuman
1 year ago
#1 1 year ago
So I've wanted to replace the flipper assemblies and linkages for my 1953 Gottlieb Grand Slam, but I was wondering if there is any easier way to go about it rather than having to cut and drill from bakelite pieces.
I really want to get the flippers re-assembled but this is the one annoying hurdle I'm facing!
#2 1 year ago
If you aren’t a stickler for original parts. Get a 1990s WPC rebuild kit, flipper plates and a couple coil brackets and your all set and it’s cheaper than the first version of rebuild kit Steve young offers.
Your flippers will be stronger too. Basically you are getting all new flippers less the coil and bats
I will be doing this during my playfield swap of 1950 Knock Out.
#3 1 year ago
Quoted from EJS:
Have you tried that before, and did it work? I was figuring you could just use more "modern" assemblies, but I wanted to confirm to make sure it was possible.
#4 1 year ago
Quoted from HydrogenHuman:
I’ve probably done 5 or 6 games and my friend has done maybe 20+
Here’s my super soccer playfield laying in a closet. Obviously I just need to add the kit. If the diameter of the coils is smaller you might add an extra washer on either the flipper coil stop or the support bracket.
Most importantly make sure you have room for your new flipper plate
29361070-8B1F-48B4-A6A9-5E690D18F10B (resized).jpeg29361070-8B1F-48B4-A6A9-5E690D18F10B (resized).jpeg
#5 1 year ago
Quoted from EJS:
Which specific kit do you usually purchase, and from where?
#6 1 year ago
Rebuild kit:
https://www.pinballlife.com/flipper-rebuild-kit-williamsbally-081993-101998-spooky-2014-present-jjp-2012-present.html
Correct EOS. I haven't tried the older kits which include proper EOS:
https://www.pinballlife.com/williamsbally-end-of-stroke-switch-normally-closed.html
Bracket for the other side of the coil:
https://www.pinballlife.com/williamsbally-solenoidcoil-bracket.html
You'll need hardware to mount this to the plate since the plate is drilled for larger coils.
Bushings (thought these came with kit but I guess not) don't forget hardware to mount:
https://www.pinballlife.com/williamsbally-nylon-flipper-bushing.html
Rubber Grommet:
https://www.pinballlife.com/williamsbally-rubber-bumper-pluggrommet.html
Left plate:
https://www.pinballlife.com/williamsbally-left-staked-flipper-base-sub-assembly.html
Right plate:
https://www.pinballlife.com/williamsbally-right-staked-flipper-base-sub-assembly.html
Grab some extra hardware to mount the plates. Extra washers too if you need to adjust your coil. Some games are ok others I have to shim up or down a little.
This is the first time I've compiled a list like this for this so I apologize in advance if I've forgotten anything. I think this is it though. My friend repairs games for a living so I get to "borrow" parts when I come up short on things.
To be honest I noticed prices have gone up a little so if you feel this might be cost prohibitive you could pick up some bakelite to fit from Steve Young but I love the feel of these flippers on older machines if you can budget it.
#7 1 year ago
The assemblies may be tough to recreate but the linkages should be easy. Do you have the old linkages? If so, it's not too complicated to take the old ones and use them to mark where to cut out and then drill the bakelite. I use a short screw and lock nut (with some heat shrink around the screw) for the post that opens the EOS switch. The one in the photo below is from a Twin Bill that had a sloppy linkage, but the linkages on Grand Slam are similar and so it shouldn't take too much effort or time to make them.
Pinball Resource has the material for $1.75 and it can make a few ("MAT-LINK" on Tools/Supplies page: "Link Material - Did you ever run accros[sic] a broken Flipper or Slingshot link and did not have one in your tool box to replace it? Do you have an unusual Flipper Link that no vendor offers? We are offering the Link material so you can make your own! This is sold in a strip: 7/8” Wide by 12” Long by 0.125 Thick(1/8”)").
How bad are the assemblies? Got any photos?
If the assemblies are too worn to function well (I've seen some with posts that are so badly worn from years of play that they are thin as a toothpick and ready to break or are just too sloppy in action), you might want to check if anyone has any appropriate spares in the EM seeking parts thread. Based on my recollection, the assemblies for early to mid 50s Gottliebs are all the same except for the orientation of the post that interacts with the link (some go up; others down).
#8 1 year ago
Quoted from tfduda:
I do have the original linkages and yep, I used them for reference! I actually have one bakelite already cut and drilled, but I ran into an issue where, the short screw I used ended up blocking the coil plunger from turning completely, which is the current problem.
#9 1 year ago
? - Not sure I get what you mean. Doesn't the plunger just pull straight back into the coil?
#10 1 year ago
Quoted from tfduda:
The set screw going into the pawl or however you spell it.
#11 1 year ago
EDIT: Actually, since I have most of the parts already for rebuilding it traditionally, maybe I can get a spare linkage somehow.
This page was printed from https://pinside.com/pinball/forum/topic/grand-slam-1953-flipper-links-do-i-have-to-make-them and we tried optimising it for printing. Some page elements may have been deliberately hidden.
