Scores do not reset at startup. Occasionally they will pulse once, but not to zero.
If I manually activate multiple times # 1,2,&3 reset relays all scores do reset to zero.
Manual mentions # 1,2,3 relays pulsed thru cam switch b&d. Also thru reset relay. Reset relay has been cleaned and adjusted properly.
I am confused as to what is Cam b and cam d.
Any hints appreciated. As always thank you in advance.
-Barry
