(Topic ID: 347084)
grand prix right bonus always subtracting*FIXED*
By vipertblck
10 months ago
#1 10 months ago
grand prix R bonus always steps down. i can manually trigger it up to rack some points on playfield lights, but then when you try to play a game, it just decresases them 5000 pts at a time each time a bonus target is hit. when you reset a game, the left starts out at 5k, and the right is zero, meaning no bonus lights are lit.
-if i manually rack up right bonus points to get 15 or 20k lit up, flick some left bonus targets...it will decrease the right bonus points lights on the playfield, while adding the left side bonus lights on the playfield.
i know this prolly sounds very confusing, trust me (it's even worse actually being here working on it). ive tried explaining this the best i could, but basically it seems the right bonus unit is starting off 1 step too low. it needs to be one step higher in order to illuminate the 5k bonus light on the playfield, just as the left bonus unit is doing. once that is figured, i think we can move forward as to why it steps down the right bonus when it shouldn't.
**also, the change relay isn't working, not sure it's tied to this issue. shoot the ball out of the lane and one of the first targets it can potentially hit on the top of playfield "advance right bonus when lit" or "advance left bonus when lit". hitting these targets should alternate to the other. meaning hit the one that's lit for left bonus, it should switch the light to the right target. this is not occuring. not sure it's related to the above mentioned issue, but wanted to leave all info i could**
#2 10 months ago
For the bonus problem, find the R. Bonus relay. On this relay find the normally open switch with the BLU-B wire and a BLU-O wire. Check for a closed or shorted switch.
The change relay pulls in by a blade switch on the 00-90 unit. Clean switch and check that the unit is advancing properly.
#3 10 months ago
One of the two bonus steppers is located at the very bottom of the playfield. I'd suggest looking at that stepper including the wires and the switch tabs where the wires are soldered. The position of this stepper leads itself to potential damage.
#4 10 months ago
If the playfield has been pulled forward during work it will rest on the right bonus unit. That can cause the board to rotate slightly, misaligning the position of the rivets causing unexpected problems. Try grasping the board and turning it back to where the rivets line up properly. (You can also loosen the board screws to do this but probably don't need to.) This may or may not fix your problem but only takes a moment to check before you dig deeper. While inspecting you can possibly spot other problems caused by resting the bonus unit on the front edge of the cabinet. (as mentioned in Post 3)
Quoted from vipertblck:
I think the change relay is at the very very top edge of the playfield (Or at the very bottom when the playfield is propped up in the service position.) Check the switches on it by manually operating the relay on and off.
#5 10 months ago
Quoted from pinballdaveh:
checked this, didnt have those color combos on any of my switches on the right bonus relay. i have a blue/black wire switch with a yellow/blue wire. or i have a blue/orange wire with a yellow wire.
regardless we made progress, the blue/black with yellow/blue wire had 1 strand of wire jumping them. fixed that and now we're not subtracting the right bonus. here's where it's at now.
1-on a game reset, the right unit doesn't zero and start fresh at 5000, stays where ever the last game ended. middle of a game, turn off or unplug and turn back on, game over is illuminated. close outhole switch and left bonus unit counts down, push credit button and it does reset cycle and shoots ball out, left bonus is at 5000 and right bonus is wherever it was in previous game.
2-whatever side the arrow is lit up to score, after ball drains it racks those points and steps down the unit, shoots ball to lane, returns unit to 5000, and then steps up the opposite side unit.
as far as the change relay...
1-what and where is the 00-90 unit? many of my stickers are gone and i couldn't find that unit labeled in the instruction manual.
2-closing the change relay manually with my finger DOES alternate the lights on the top of playfield.
#6 10 months ago
did some more tampering. left side seems to be working ok...i think. overall right now it seems like the left bonus unit isn't resetting. it thinks it's resetting and firing the step up coil as it should, which is why when the left side drains the left bonus unit down, it fires up 1 click to the 5k mark. but, since the right side bonus unit isn't resetting, it doesn't know that and it's till firing up to what should be the 5k mark. i checked the blue/orange and green wire switch on scm 2D, and that seems to be making good connection. is there somewhere down the line after this that fires the reset coil on the right bonus unit?
the b1-26-800 coil on right bonus unit should be firing for a reset when the ball drains, but it is not. it is working because when it steps down and scores the bonus for the right side, i see the coil firing as the bonus light steps down. but when it drains a ball and is scoring the left bonus, the right side should reset to zero and then step up to 5k when the ball shoots to lane, this isn't happening.
#7 10 months ago
The 00-90 unit is near the top of the backbox in between the 1st and 2nd player score reels.
#8 10 months ago
00-90 unit just needed the switch adjusted. working properly and moving the change relay and alternating the light. right bonus unit seems to be fixed too, had some incorrect wire labeling on the schematic and machine it seems
1,200 (OBO)
San Antonio, TX
Raleigh, NC
$ 24.98
Hardware
Gameroom Mods
$ 44.99
Pinball Shark
Great pinball charity
Pinball Edu
