New game in, starts no problem and hear the reels reset. Problem is no switch registers any points, after a few test hits it sounds like one of the chime switches lock in. Where should i start troubleshooting? Thanks.
Quoted from xddanx:it sounds like one of the chime switches lock in
Find out if that's happening because most coils in an EM pinball will self destruct under constant power
I fixed the chime and moved on to the point relays. If I tap a 10 point switch the 10 point relay fires and resets but no movement on score reel. With the 100, 1000 and 10000 if one of the switches on the playield is hit causes the corresponding relay to fire and lock on, what would cause this( no score reel movement)?
Quoted from xddanx:With the 100, 1000 and 10000 if one of the switches on the playield is hit causes the corresponding relay to fire and lock on,
Quoted from HowardR:most coils in an EM pinball will self destruct under constant power
Quoted from xddanx:If I tap a 10 point switch the 10 point relay fires and resets but no movement on score reel
Inspect and diagnose this circuit with Alligator clip jumper wires
Starting with the Player Unit wiper & disk
http://www.planetimming.com/Pinball/troubleshooting/EM%20Troubleshooting.pdf
http://www.pinrepair.com/em/index3.htm#features
This page was printed from https://pinside.com/pinball/forum/topic/grand-prix-not-scoring- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
