Hi Barry
good - the ipdb has the schematic and the manual --- there on page-12 (ori-10) I learn: The Right Advance relay is mounted on the playfield, the Right Eject-Switch is part of the Right Eject-Hole - therefore is mounted on the playfield, the Right Bonus Unit is mounted on the playfield.
BUT the Score-Motor sits on the Mech-Panel in the Cabinet - there must be a wire from the Mech-Panel of color-B-W-3 means Black-White but this color is also used on non-related other places - anyway: The manual on page-14 (ori-12) shows an Size "22" Jones-Plug in the connection Mech-Panel to Playfield --- see in position-6 the mentioned wire-color-B-W-3 --- all good with this Jones-Plug ?
If You do not find an error there - we then must investigate in the Score-Motor-cam named "3" we see in the schematics --- Bottom-most switch in the stack is SCM-3-A. Greetings Rolf
P.S.: My JPG shows: Maybe the wire coming from SCM-3A then is connected to "A" or maybe to "B" or maybe to "C" --- so have a look at "Right Advance-Relay (wires soldered-on ?) - have a look at the Right Eject-Hole-Switch (wires soldered-on ?) - have a look at Right Bonus-Step-up-Coil (wires soldered-on ?) Greetings Rolf
