After thinking about it a little more, there are several things that have to be working in order for the machine to go from Player 4, Ball 1 to Player 1, Ball 2:
- The Player Unit and Coin Unit need to be moving properly and all the spider finger connections have to be made. As far as stepping up to the next ball is concerned, the Coin Unit is involved in a 1-3 player game, but a 4-player game bypasses the Coin Unit and goes through the Player Unit only to fire the Ball Count Unit S.U. coil.
- It sounds like your Player Unit S.U. coil is firing since you're able to go through Players 1-4.
- In order for your machine to go back to Player 1, the Player Reset Relay has to fire, so the EOS switch on the Ball Count Unit S.U. coil needs to work. There is also a M/B switch on the Player Reset relay that has to switch.
- After the Player Reset Relay fires, the Player Unit Reset coil should fire - that takes the Player Unit back to Player 1 from wherever it is.
