Well, im not even close to a professional solderer, that should be told, i just warmed up the soldering that was already there and made sure the diode (thanks wayout, im not a electrician either ) got stuck properly, so maybe that warmup disturbed the other cable on that pin too, will check.
And ive have now opened up and checked all 4 flippers:
Plungers all looked fine, no mushrooming.
Return springs seemed nice and springy (except one on the lower right that felt abit loose, but that flipper works just fine so i'll just make a replacement note of it for the moment) and none broken.
All EOS i have cleaned off and filed with a file very carefully, gaps are untouched and should be as they where.
Coil stops all looked almost new, except for some grime (someone seemed to have put lube on the plungers at one time, which i know is a big NO-NO, cleaned that stuff off from all 4).
Coil sleeves where just dirty so i cleaned them out, made them look like brand new.
And i also switched out 5 of the flat cables from the soundboard and the display board, but both lower displays are still dead, and switching cables didnt help with the music either, but i bought that replacement Grand Lizard soundboard from Marco's which is in shipping as we speak (damn shipping cost a fortune though, does US customs hide leadbars in the package or something??)
And ive also noticed that the two upper displays have begun to slightly flicker and the right one ghosts abit on the first number, are they dying?
And, well, if im supposed to fix all that grubby wiring, i'll might aswell start saving away cash for a completely new gamefield since ALL the wiring looks the same, which is why i am very VERY apprehensive to touch anything too hard when working around on the underside.
Quoted from BCpinhead:It is a two-stage flipper button right? Light pressure activates lower flippers only. So I bet you have a) grubby wiring to clean as mentioned and also b) all flipper button switch blade contacts that needs a good de grubbing and light flex stone. Bet that does the trick.
Yeah, the old kind, and i filed and cleaned those too, and cables looks fine as far as i can see.
