OK, let's try that again, but this time for real:
This is a high voltage test, so make sure you have rubber shoes on and are NOT touching any other machines or any metal on the Grand Lizard. Do not lean on the metal rails. I can't be responsible if you kill yourself, or zap your cock by pressing it against the rails.
The power supply board has the giant heat sink on it.
The upper left connector should be labeled 3J5 (display power connector)
6 pin connector, and pin 1 is on the Left.
Put your meter on DC.
Put black meter lead on pin 1(black wire).
Put red lead on pin 3 (orn/bk/wht) = Negative 100v (-100v)
Put red lead on pin 4 (brown wire) = +100v
Put red lead on pin 6 (gray wire) = +5v
