Ive created this thread to soley generate some awareness of the current ghosting and pf issues. Build date os May/16.
Be extremely cautious about purchasing any Stern pin around this build date and to probably tag 4 months ar least on either side to be sure. At least until Stern resolves this collosal goatf@#k that is their playfields.
These pics are from a gble less than 150 games, few weeks old huo.
There is substancial cracking in and around inserts. The cracking looks like fishscales in the ghosting.
Note there is cracking all around the storage insert then a crack runs from that to the super jp insert. You need to look closely but its there and when you run your fingers over it its a crack not just the feel you get with an edge of an insert. There is other cracking and ghosting in the pf but this is the worst.
Also the bottom of the arrow above the L in librarian the insert has significantly dropped which is hard to see in the photos but there is a big divet.
Suffice to say be careful. Also these are cracks that developed over the few weeks.
