(Topic ID: 333706)
Gottlieb sys80 power supply rebuild
By ravve
1 year ago
  • 5 posts
  • 2 Pinsiders participating
  • Latest reply 1 year ago by ravve
#1 1 year ago
I have a Gottlieb Super Orbit (1983,system 80?) and a diode (cr7) on the power sypply board has gone bad.
I have been reading here and on pinwiki, where according to pinwiki it is mandatory to replace cr7, R10, R3 and the potentiometer.
I am only looking to fix the game. Would it be enough to only replace the broken diode cr7 and R10 according to pinwikis suggestion, but not the potentiometer and R3?
Why is replacing the potentiometer and R3 mandatory?
#2 1 year ago
Super Orbit is System 80A
Quoted from ravve:
Because it's 40 years old and likely deteriorated/contaminated to the point that it cannot hold a stable output voltage. Otherwise, if yours is working, then don't change it. These are only some established recommendations for improving operation and reliability.
Also, taking this board apart is a total pain in the ass. As per Pinwiki: "a good strategy is to replace all failure prone parts, whether the parts have failed or not, to avoid disassembling the power supply more than once."
#3 1 year ago
Quoted from sparky672:
How about the resistor R3, do you have any idea why it is "mandatory" to replace it? I can confirm that it is measuring (and looking) fine. Maybe it is necessary due to that cr7 and R10 are to be replaced for other values than the original?
Also, I can only find resistors of 0.25W or 1W, pinwiki says 0.5W. Which one should I go for, 0.25W? Or maybe 1W is a better option?
And the most important question: The trim pot, I read that it should be replaced by 500ohm 1W, but I can only find 500ohm 0.5W, would that work??
#4 1 year ago
Quoted from ravve:
For the same reason. It's a very cheap component that is prone to failure and separating this board from the heat-sink plate is a royal pain in the ass. Replace what you can when you have the chance.
Quoted from ravve:
Wattage rating is the MAXIMUM power the resistor can handle. When in doubt, go UP... never go down. If you need ½-watt then ½-watt is the MINIMUM you should use.
Quoted from ravve:
Where is it saying to use 1-watt? The circuit shows this pot in series with ¼-watt resistors R7 and R14, so if ¼-watt resistors can handle the branch current, then so will a ¼-watt potentiometer. Otherwise, the original R7 and R14 resistors would have burned up decades ago.
Screen Shot 2023-03-23 at 11.46.39 AM (resized).pngScreen Shot 2023-03-23 at 11.46.39 AM (resized).png
I replaced mine with this ¼-watt pot 2 years ago - no issues.
https://a.co/d/9v6dh7h
For this pot, 0-500 ohms is the range you need. If you can only find 0-750 ohms, that would work too. You can go up a little on the pot's resistance within reason. Example, if you use a 0-1,000 ohm, then only the first half of the number of screw-turns will be 0-500 ohms. If you use a 0-10,000 ohm, then the 0-500 ohms will be so low within the number of turns, adjusting it will be very difficult. Try to get something as close to 500 ohms as possible without going too far over. The closer you get to 500, the easier adjusting it will be.
Finally, the number of potentiometer turns. If you get a higher number of screw turns, then adjusting it for precise voltage will be much easier. More turns to achieve the same amount of change.
#5 1 year ago
Well thank you very much, really helpful information
I'll go ahead with the 0.5W potentiometer then, cheers and thanks again!
$ 83.00
PinballReplacementParts
This page was printed from https://pinside.com/pinball/forum/topic/gottlien-sys80-power-supply-rebuild and we tried optimising it for printing. Some page elements may have been deliberately hidden.
