1st off, excuse me if I get terms and part names wrong. I am a bit of a novice with pins.
About a year and a half ago I picked up a "nonworking" Golden Arrow pin in a 3 machine purchase. The other machines were arcade cabs. It was an all or nothing deal and the Golden Arrow machine is the 1st and only pin I have ever owned. I had the pin up and working in 5 mins. The ball return was jammed. The play area was not in bad shape at all. It shows ware, but I have seen worse (even on these forums) when I was researching it.
Since then I have clean the play area, replaced the rubbers and ball. There are a few plastic parts on the table that need replaced. They were brittle when I purchased it and one has since broke. There are 7 across the table of 3 different sizes. The are around the lanes at the top of the playfeild and 1 on each side of the middle of the playfield.
Where could I find these pieces?
Thanks in advance
B
