Repairing a Gottlieb Stage Coach at the moment and have a couple of issues that I can’t seem to fix.
The hall release from what I read should drop out once all halls are released and you score 10k.
This machine will let you play multiple balls and accrue points (10k or 100k) and will not release the ball until you score 1 point( this game has a single point scoring system seperate to the usual points score in 10, 100k and millions) and then a 10k amount before ball release drops out. You could in theory play endless balls and provided you don’t Criss a 1 point button Keep accruing a score. The 1 point buttons are not so easy to hit so this is an issue. In addition the gobble holes and outhole don’t score until the ball release drops out.
The 10k also resets at start up but does not always reset to zero, but any random 10k amount. Any help much appreciated.
