I am in the process of enabling the operation of coin mechanisms on each of my machines. Naturally each requires a coin box but in my experience EMs are rarely sold with coin boxes.
I have also had some difficulty in precisely identifying what spec coin box was supplied in a particular machine. So when pinballgirl recently advertised on ebay a pristine rarely advertised coin box for a woodrail I placed a bid but ultimately did not win and it went for $US61. But thankfully pinballgirl was good enough to provide the coin box dimensions.
Now in Australia we have a saying 'if you can't beat EM-join EM'; so I decided that 'if can't buy EM-make EM. I obtained a sheet of galvanised sheet metal 20g from the local recycling outlet for $2; purchased a sheetmetal bend brake for $50 similar to the Harbor Freight model
http://www.harborfreight.com/18-inch-bending-brake-39103.html
& which I will use for other bending projects such as brackets etc and called on my spot welder which I had previously used for car repairs to spot the sides as per the original. I am reasonably happy with the result after first making a cardboard profile. It was lucky I did because the width dimension provided by pinballgirl was 1/4in wider than the opening in my Rocketship so adjustment was required. These are the progressive pics:
Finally I applied the Gottlieb A4658 label and again I extend my sincere thanks to Peter Koch for producing this label which I understand is now on his website.
