Hi.
I have a gottlieb Wipeout that won't boot.
DMD controller LED is stuck on. Tried replacing U8 GAL to no success.
Does anyone know if the DMC Led should flash even if the ribbon cable to the Mpu is not connected?
If I have the ribbon cable connected to the DMC the CPU led flashes for about 2 seconds then turns off for a second, then repeats. If the ribbon cable is not connected the Mpu led flashes for a bout 1 second before it goes blank and repeats.
I hear two beeping sounds of different frequency when I power on the machine.
5v is ok and I have replaced the battery with a cr2032 and I get 3.2v from it.
