(Topic ID: 280576)
Gottlieb - what pins used on A2J1 & J2?
By Topher5000
    #1 3 years ago
    A while back I got housings from Digi-Key for A2J1 & J2. I searched the Molex # on Digi-Key & they listed the replacement.
    I only had the plain 08-052-0072 pins and bifurcons, so I used the -0072. Problem is they pull out the back. Should I use trifurcons?
    #2 3 years ago
    Never mind - I found a thread & Chris Hibler answered trifurcons. The thread was mine
    #3 3 years ago
    Link to the thread? Just for future searches sake.
    #4 3 years ago
    If the contacts pull back out then you bent the 'tang' on the back side of the contact.
    Take a look at this image - you will see a small metal flange sticking out on the backside. Sounds like yours is not bent out and is flush or nearly flush.
    #5 3 years ago
    I’ve been working on some sys1 amd sy80 and when I pull a pin out to check I just use a pick to pick that tab back out and push the pin back in
    #6 3 years ago
    Quoted from G-P-E:
    Take a look at this image - you will see a small metal flange sticking out on the backside. Sounds like yours is not bent out and is flush or nearly flush. [quoted image]
    I'll have to take a look. I don't see how I could have done that. I've re-pinned a few & this is a first. Especially all four pins.
    #7 3 years ago
    Quoted from Isochronic_Frost:
    This is the thread: https://pinside.com/pinball/forum/topic/re-pinning-gottlieb-80b-ps
    #8 3 years ago
    I bet I have them in upside down.
    This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-what-pins-used-on-a2j1-amp-j2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
