(Topic ID: 209609)
Gottlieb WH Royal guard problem
By SteamVette
6 years ago
  • 4 posts
  • 4 Pinsiders participating
  • Latest reply 6 years ago by MarkG
#1 6 years ago
Hey all, My Royal guard machine is making a very loud hum. I isolated the problem to the unit (step unit?) in the back head. Pulled the cover off and solenoid was very very hot. Would this be a open relay somewhere? I'm new to working on pinball machines and reading the schematics. I own 5 Wedgeheads and have done some minor repair/ fixes and love tinkering on old equipment.
Thanks,
Jeff
#2 6 years ago
1. A switch is stuck on the play field
2. The Unit is stick or froze.
3.A Relay is stuck closed sending continuous power to the coil
4. A short is sending power to the coil.
#3 6 years ago
That is your one point unit. It's a continuous step unit. The cause is almost assuredly a closed switch somewhere on the playfield.
#4 6 years ago
If that's your 0-9 unit (can't read the label in the photo) it's solenoid is probably being held in by the N relay which is the 1 point relay. Is that relay stuck on too? It's probably in the head, not far from the score reels.
If you can't find a stuck 1 point switch on the playfield as EMsInKC suggested, check the normally closed switch on the 1pt score reel. That should open when the score reel advances, releasing the N relay which should release the 0-9 unit solenoid.
/Mark
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-wh-royal-guard-problem and we tried optimising it for printing. Some page elements may have been deliberately hidden.
