(Topic ID: 227620)
Gottlieb Volley - no playfield features score
By arolden
1 year ago
  • 23 posts
  • 9 Pinsiders participating
  • Latest reply 1 year ago by D-Gottlieb
#1 1 year ago
Hi everyone
I am working on a Gottlieb Volley and am stuck with my troubleshooting on this one. None of the playfield switches are activating any of the score reels. The game starts without issue, kicks the ball into the shooter lane, advances through the balls and goes into game over mode without issue. Playfield lights are on. Everything seems OK except for the fact that nothing will activate the score reels.
When I manually activate the L, M, N relays, the score reel advances and the chimes go off. However, the relays do not do anything when a playfield switch is hit. Pressing the 500 and 5000 relays in the cabinet will advance the score motor, but the score reels will not advance. It's not stuck in tilt. The Jones plugs between the playfield and backbox are securely connected and I have cleaned the contacts on them. No blown fuses anywhere. No playfield switches are stuck closed.
It's like there is a total disconnect between the playfield and score reels but I cannot find where that break is.
Any ideas?
#2 1 year ago
Reply sent in private message.
#4 1 year ago
Quoted from HowardR:
What's the big secret?
Check you have all the Jones plugs connected. There is a smaller one from the playfield that can get missed.
#5 1 year ago
Quoted from woz:
I agree with the big secret. The forum is here to share knowledge, not sequester it.
#6 1 year ago
Maybe there is something in the email that can't be shared in the public forum..
#7 1 year ago
Quoted from bonzo71:
Thanks, bonzo71 you're exactly right. I upvoted your post.
#8 1 year ago
Quoted from woz:
Yes, I'm sure they are all connected. There are 3 in total.
#9 1 year ago
Some further thoughts.
The 10, 100 and 1000 point relays work fine when activated manually. So the issue must be downstream of there. According to the schematic, each relay passes through a switch at 4A. The target bank reset relay also passes through 4A and works fine, so 4A cannot be the issue.
The manual states that scoring is through 1A. I inspected both switches at 1A and cleaned the contacts. They activate properly so they can't be the issue either.
The hunt continues...
#10 1 year ago
Are the flippers and pop bumpers working?
#11 1 year ago
there is a switch /contact on the ball in play unit that closes when it advances to ball 1 and energizes the pf. This probably needs cleaning
#12 1 year ago
Quoted from Pinbee:
Yes
Quoted from pinhead52:
I'll try that tonight
#13 1 year ago
The playfield scoring is isolated at startup thru a switch on the reset relay. I would check the AX relay.
#14 1 year ago
I agree with the above 2 posts regarding the ball count unit and AX relay.
#15 1 year ago
Quoted from D-Gottlieb:
if the flippers are working its not the ball count switch
#16 1 year ago
Quoted from arolden:
If the 10 Point (N) relay doesn't activate when you hit the 10 point playfield switches, inspect and diagnose this circuit with Alligator clip jumper wires, starting with these 2 switches.
#17 1 year ago
Yes, that's right.
#18 1 year ago
OK, bear with me here as I am new at EM troubleshooting. As I understand it, I need to jumper the black wire on the 10 point relay to the MAR-YEL wire attached to the V relay, then to the RED+WH wire attached to the switch at 1C on the score motor. Is that right?
#19 1 year ago
Good job, arolden, trying to figure this out, and asking too. I'm sorry to say what you suggest will blow a fuse. I'm kind of busy Monday & Tuesday but if you'd like to try a phone call when I can fit you in, send me your cell # in a private message.
Otherwise
Watch those 2 switches as they work, making sure in each case that the long blade moves the short blade a little bit.
Then try jumpering the Maroon+Yellow wire on a V relay switch to a Red+White wire on a Motor 1C switch, reset the game, and press a playfield 10 point switch.
#20 1 year ago
I'm going to suggest also that you verify the make-break switch on relay "V" ( add replay unit relay ) and the motor 1C switch are clean and making contact. The switch at 1C is the outermost on the stack, and is in the circuit to playboard contacts.
#21 1 year ago
I checked the AX and V relays and both of them were well adjusted. So then I had a look at motor switch 1C. It was making good contact physically, but when I tested it with my meter, there was no continuity. I gave it a light sand with flexstone and then I got good continuity across the contacts. That turned out to be the problem and now the game scores!
Thanks to everyone who offered advice. This was a good exercise in reading schematics for me so even though it was a simple issue, I spent a lot of time trying to understand the circuit.
One last question: when looking at the V relay, what is the easiest way to tell which switch on the relay is part of this circuit? Is the wire colour the only clue?
#22 1 year ago
wire color and style of contact. 3 styles, NO (normally open) NC (normally closed) and then "C" which has a center blade and both a NC and NO piece.
So i use style and wire color to find the switch.
#23 1 year ago
Good job on chasing that down.
$ 4.49
Third Coast Pinball
$ 19.95
$ 199.00
Medisinyl Mods
Medisinyl Mods
$ 4.49
$ 16.00
Pin Monk
$ 3.00
Various Other Swag
Project Pinball Charity
$ 19.95
Flashinstinct
$ 29.90
$ 9.99
Bent Mods
$ 18.95
$ 14.95
$ 46.99
Lee's Parts
Pinfarmer Mods
£ 50.00
Sillyoldelf Mods
