Gottlieb Total Play Meter repair
(Topic ID: 231842)
By JMPT
36 days ago
  • 9 posts
  • 6 Pinsiders participating
  • Latest reply 11 days ago by JMPT
    #1 36 days ago
    Hi.
    Has anyone ever tried to take apart a Total Play Meter ? (and put it back together!)
    I have looked all over the web, and found absolutely nothing. No spare parts, no units for sale. Nothing, people just don’t care about them…
    The problem with my unit is that when the coil activates, the first digit does not completely move to the next number, it just goes back and forth about ½ a number.
    You can view an animation of what happens at this address :
    http://jm-thoridnet.fr/flipper/meter.mp4
    There is a sprocket on the inside of the first reel, which is pushed on by the plastic part when it moves down. Something is probably worn in one or both these parts, the reason why it doesn’t rotate as much as it should. Basically the first reel is the motor.
    The way the next reel in line is incremented, is the little piece of ”cog” you see between the firsts’ reels ‘ and 5, that is the same for all the others except the last, which when it comes down to the little black cog below, turns the next reel, and so on…
    I think the only thing you can do is remove the top axel that holds the number reels. There is a circlip behind the washer next to the “9”, which in my opinion keep the axel in position. You can also see a spring before the washer
    Thanks, JMPT
    #2 36 days ago
    Yes!
    Took about 8 apart and now they all work perfect.
    On all mine the little bar where the cogs sit, rusts and so wheels jam.
    The ones I took apart were 50's, so they are different to yours.
    They were fairly easy to take apart but took me ages to get back together again correctly.
    #3 36 days ago
    there is a little post on the first digit that gets broken off as well. one solution is to swap top digit for bottom digit but yea a real pain to get back together
    #4 36 days ago
    Repair parts to fix a meter are not available because you can buy a complete brand new meter for $10.
    #5 35 days ago
    yes, but where's the fun in that Ken?
    #6 34 days ago
    I took a Williams unit apart a while back because it wasn't working. Turned out to have a burned out (and badly melted) coil.
    While swapping out a coil is easy, doing anything else with a play counter is not. They're a nuisance to disassemble and reassemble, and as others have pointed out, you can pick up a used working one for about $10 on eBay, which, as it happens, is what I had to spend to buy a new coil.
    You could probably fix it, but for me, this falls into that "life's too short to spend much time on this" category.
    My 2¢. YMMV.
    #7 34 days ago
    Thank you.
    I agree that it’s ’’more fun to compete’’ with the fixing aspect, plus you keep the original machine intact, but it’s good to have a safety net ! There is no reason not to try now.
    Where can you buy one ?
    On the fixing side, I imagined correctly, that the hard part is putting it all back together especially the reels and that little spring + washer and circplip which if I’m correct keeps the axel from slipping out. An idea might be using a paper clamp to keep them together ??
    What problems did you encounter ?
    JMPT
    #8 34 days ago
    yep you’re right found one on ebay US :$ 14.95 +$28 shiping...
    JMPT
    3 weeks later
    #9 11 days ago
    If you are interestedin repairs I started a new post : How to disassemble and reasssemble a Total Play Meter.
    $ 99.00
    € 27.00
    YOYOKOPTER MODS
    $ 70.00
    $ 12.00
    $ 69.99
    $ 28.95
    $ 5,799.00
    Classic Game Rooms
    $ 430.00
    MI Pinball Refinery
    $ 7,299.00
    Flip N Out Pinball
    CzTV Mods
    $ 49.00
    The MOD Couple
    $ 7,199.00
    Classic Game Rooms
    $ 179.00
    Great American Pinball
    $ 9.99
    $ 24.99
    Lee's Parts
