Quoted from cperro:Also, I'm a bit confused on how the replay wheel works (as stated above it thinks 5 is zero). Could someone explain how it works and how to manually add credits to it properly (don't know if I was doing it properly adding credits when I played around with it)? Thanks!
The replay wheel, or credit unit, is a stepper unit that steps forwards (to add a credit) or backwards (to subtract a credit) one step at a time. There is a solenoid for each direction. If you manually push the plunger into either solenoid and release it, you should be able to add or subtract one credit at a time if you're not at one limit or the other.
There are screws sticking out of the geared wheel that close the limit switches mounted above the geared wheel. One limit switch opens at 0 credits and the other opens when the maximum number of credits (15?) is reached. There's closeup video of a credit unit at www.funwithpinball.com/small-boards#CreditUnit
If your unit thinks that five is zero, it sounds like one of the limit switches is opening too soon. Have a close look at the end of the video to see how the zero limit switch should open.
/Mark
