I'm trying to get a Gottlieb Mustang up and running, but I'm having trouble with the tilt hold relay energizing as soon as the game is powered on. I assume this is because a tilt switch is closed somewhere, the trouble is I am not totally clear which switch is which.
Looking at the schematic I see that there are three tilt switches and an anti-cheat switch. I don't see a reference to a bounce switch, but I may have missed it.
So I am trying to understand where I can find and identify all the tilt switches. Here are images of switches I believe are involved. Please correct me if any of these are wrong.
The first is in the light box, pretty sure this is a standard tilt switch.
The second is the switch under the playfield, pretty sure this is a standard tilt switch.
The third is the ball in groove and tilt bob. There are two switches here including the tilt bob. I am not clear how these are represented on the schematic. Are they included in the three tilt switches?
The forth is a switch in the cabinet next to the score motor. I thought this was the bounce switch, but is this a tilt switch? If so, I have other problems because the game won't start if this is open.
The fifth is on the coin door, this is the anti-cheat switch right?
Thanks in advance for any and all help.
