(Topic ID: 264860)
Gottlieb system80B soundboard: extended sound set?
By bontango
3 months ago
  • 2 posts
  • 2 Pinsiders participating
  • Latest reply 3 months ago by lucky1
#1 3 months ago
Hello,
I'm working on including more sound into my 'LISY80' (www.lisy.dev) by experimenting with a system80B soundcard of a #Victory
Because Gottlieb spend only 5 wires to control the sound I was under the imagination that the maximum number of sounds
for a system80 Gottlieb is 32. However by playing all the 32 sounds manually (by let LISY sending the codes to the soundboard)
I did not hear these 'Checkpoint one', 'Checkpoint two', .. speeches.
By incident I figured out that Gottlieb did implement an 'extended sound set' which is controlled by soundnumber 0x1D (29 decimal)
When I send soundnumber 0x1D no sound is played, but it has an impact of the sound playing after that sound.
For example if I send sound 0x1E (28 decimal) there is an engine noise, but if I send two codes 0x1D AND 0x1E it says 'Checkpoint one',
same for the combination 0x1D AND 0x1C ( Checkpoint two). So obviously Gottlieb extended the soundnumbers on Victory Soundboard
by introducing this 'control code' 0x1D.
Before I try to figure out more by doing more experiments I wanted to ask if anyone have more information on this feature?
Is it used for all system80B soundboards, are there other 'control codes' introducing a possible 'third sound set'?
thanks for your help
Ralf
#2 3 months ago
Hi Ralf,
maybe it is the same like WPC89 machines where a sound byte (0x7A for WPC89) is used to extend the range and the soundboard waits for a second command.
$ 52.00
Gweem's Mods
Cabinet Parts
Ramp-O-Matic
$ 299.00
Displays
Boston Pinball Company
€ 8.40
$ 5,899.00
Classic Game Rooms
$ 12.99
€ 8.10
Buthamburg
$ 12.00
$ 29.99
$ 60.00
RobTune
$ 129.25
$ 76.95
