I just recently inherited my first pinball machine, 1979 Gottlieb Pinball pool system one machine. I have since then been trying to learn everything I can about this machine and came across this forum. There have been a few minor issues that have came up since I began playing it. The biggest one being that when the machine is turned on and left on for more than a half hour or so something happens and locks up the game and all of the score displays turn off. At this point none of the controls work and putting in another quarter and pushing the play button does nothing. I have found turning off the machine and unplugging the power supply board to CPU board cable and re-attaching it seems to be the only way to get the machine to work again. Simply turning it on and off does nothing and by process of elimination I determined it by unplugging that A1J1 power cable from the power supply and then back on stops the problem temporarily until another half hour or so when things have warmed up it will do it again.
I thought it was possibly the cable so I have replaced the A1J1 mpu power cable and also the A1J5 to A3J1 cable with new ones by docent electronics. Unfortunately this has not fixed the problem.
Can anybody recommend any possible causes of this lockup problem? Its almost as if once the machine warms up it locks up. I have contemplated replacing the power supply board with a rottendog replacement and possibly even the driver board as well just to try and rule them out.
2nd issue is that one of the (2) pop up bumpers does not work. I checked it out and could not see any signs of a switch failure or burn marks on the coil. Any ideas what to check on a system one pop bumper?
Thanks for any help/suggestions offered!
Tom
