My Gottlieb System 80B Hollywood Heat had been working fine. The first symptom of a problem was the display would not come on some times at power up. After that, usually solved by powering off and turning on again, it would stop registering certain switch closures, like the capture saucers and outhole. I discovered the labels had fallen off the EPROMS. I have been told that would likely not have been the problem. I bought a used but "pulled from a working game" Swemmer MPU. Jumpers are set properly for Hollywood Heat. I swapped EPROMS to the new board and installed (checked power supply and it was right at 5V). Not it has a slam switch warning at power up (which I can defeat by momentarily closing the switch-did not need to do this with the MPU that had been in there), and the video shows what happens.
It is as if the switches are are all rapidly closing. It seems like it is playing an invisible game.
I do not have a logic probe. On the Swemmer board, all the ICs are socketed.
Has anybody seen this before?
Thanks,
Zap
