So I picked up a working #HollywoodHeat last week, albeit it needs some love.
Saw it working before I took it home. Got it set up in the house. Everything worked aside from a blown fuse for the drop targets. And I did notice a flicker on the displays (the unused segments looked like they were dimly lit)
The next day I turn it on, walk away to do something at the computer for 5mins and notice some inserts are locked on. I shut it off. Turn it back on and nothing.
Now I get garbage on the display. A few feature lamps on the playfield doing an attract show but can’t coin up or start a game.
Typically when I first turn it on I get a couple of insert lights circling the playfield, back ic and gi comes on. The soundboard led somethings flashes other times not. If I turn it off and then back on I get the same but with a beep from the speakers.
Ground mods were done at the transformer. The mpu has the added wires on the interconnect and has a Piggy Deux board with the harness to the reset board.
The resetboard is flakey, when touched, it started a reset loop so it is now unplugged.
Reflowed the male pins on the psu and cleaned the pot. Made sure it was pushing 5v to the mpu which it is as measured at the connector as well as the 100uf 10v cap.
Also cleaned up the edge connectors on the mpu with a pink eraser.
The mpu still has the battery attached which I was going to replace with a coin cell or nvram when I make a parts order.
Tried the usually reseat the connectors, remove fluorescent tube starter tested for continuity for the grounds between boards and transformer but I get no change.
I picked up some terminal connectors and wire this morning to do the ground mods to the boards but I have a feeling I won’t see much change.
Sorry about the wall of text but this is my first Sys80b and I’m at a loss of what to try next. Any insight would be greatly appreciated!
