Have a weird one. ROMs are hard to find to verify, but I'm feeling that is probably the issue, but want to throw it out to the hive mind.
Have an Amazon Hunt, System 80A, that appears to boot but not quite. Battery removed, clean board, new 100uf logic cap at the power input, slam switch modified, clean power, passes all tests on NeoDiag80. Reset and clock working right, ready and IRQ working correctly. Had one bad switch matrix chip, z13 replaced.
There's not much activity on many of the address lines, but activity on almost all of the data lines. It boots with zeros in the displays as it should, but is not in attract mode or allows anything to play. Chip select circuitry all appears to be working well with a probe.
Would this be indicative of a potential failure on U2 or U3 or the game ROM? Could the 6502 pass this much test and be bad?
Any ideas appreciated -- thanks!
