New! Dark mode!
(Topic ID: 269837)
Gottlieb System 80 Weirdness
By Jive
4 months ago
  • 7 posts
  • 6 Pinsiders participating
  • Latest reply 41 days ago by HeyItsMeDusty
#1 4 months ago
So my Counterforce has been pretty much rock solid for the past 4 years. Ground mods were done, some connectors replaced....basic sys 80 stuff. Well, tonight I go to turn it on, and it's mostly dead. All backbox lights are on, even the controlled ones, no lights on the playfield (although they do blink when first turned on), and weirdly, the credit display shows a little "c". This could be a glitch, or it could be trying to tell me something, not sure. Power supply voltages are good, and +5v is going to the MPU. Almost seems like the MPU is locked up or something, but I am at a loss. Anyone seen anything like this before?
#2 4 months ago
Sounds to me like the MPU is locked up and didn’t boot too.
#3 4 months ago
Check components on the p/s board? My sys 80 had a toasted diode that was throwing me fits.
#4 4 months ago
Check the reset signal on pin 40 at the 6502 CPU. If it is Low (0V) reset is active and the board won't start. If it is High (5V) check if the clock signals are present. They should be there at pins 37 and 39 at the 6502 CPU and pin 39 at the 6532 RIOT's. Use a logic probe or better oscilloscope to check. If these are all ok a testrom is a nice attribute to test your CPU board. Another possibilty is to send out your board for repair to someone with decent knowledge and experience like Chris Hibbler for example.
#5 4 months ago
Quoted from MarAlb:
Good advice here.
Let's also measure for 5VDC across the electrolytic capacitor that is adjacent to the power connector, J1 on the MPU board.
Chris Hibler - CARGPB #31
http://www.ChrisHiblerPinball.com/Contact ... for board repairs
#6 4 months ago
Thanks guys, I hope to get back into it this evening.
3 months later
#7 41 days ago
Bump, did you ever figure this out?
$ 289.00
Great American Pinball
$ 37.00
The MOD Couple
$ 19.00
$ 93.00
$ 40.00
Arcade Arts
$ 24.99
Lee's Parts
$ 84.95
$ 239.00
Creo Pinball
Filament Printing
$ 299.00
$ 40.00
B & K Mods
$ 65.00
Playfield - Plastics
Ramp-O-Matic
$ 159.99
nvram.weebly.com
$ 3.00
Cabinet Parts
BK Pinball
$ 99.99
$ 69.99
$ 9.99
CzTV Mods
$ 12.95
$ 269.00
$ 139.95
