I am working on a Caveman...When I turn it on, it appears to boot up but the reset light (LED2) on the MPU stays lit. I am not sure if this is normal? I am not using the factory reset board, is there a mod or something I need to do to bypass it? The game will not coin up or go into test mode and I believe this is why.
Pinwiki says "Along with adding the reset board, Gottlieb® added a 3.0Kohm resistor across pins 7 and 11 of the reset board connection at MPU connector TC1. If not using the reset board, it's advised to add this resistor to the back of the board, as shown at right. This resistor pulls the read/write line to high when not pulled down by the 6502."
Is that what I need to do? I am hesitant to start modifying my brand new MPU. Any help would be appreciated. Thanks.
