New! Dark mode!
(Topic ID: 191404)
Gottlieb system 80 mpu corrosion
By ddd
  • 8 posts
  • 6 Pinsiders participating
  • Latest reply 3 years ago by vid1900
#1 3 years ago
This is my parents' pin, it's been sitting in their basement for a long time. I don't know the repair history other than they've had a tech work on it in the past and it's hasn't been working (or turned on) for 7 or 8 years.
I opened it up to check for damage and sure enough there is some corrosion around the battery.
However I don't see anything leaking out of the battery. Maybe it leaked in the past and this is a botched repair job. (Possibly from whoever scratched the board around this area.)
Does that seem likely from the photos or could this somehow be a slow leak from the current capacitor that I can't see?
Does this board seem salvageable or is it a lost cause? I don't mind a bit of a challenge but if it sounds like a quarter of the board needs trace repair that's probably a bit much for me.
#2 3 years ago
At a glance, the corrosion doesn't look too bad, certainly salvageable for sure.
#3 3 years ago
That doesn't look too bad. There are kits available to replace all the affected components. It does look like a half arsed repair though. Someone has sanded the affected traces but it doesn't look like they've neutralised the battery alkali so the corrosion continues.
In any case I would get that replacement battery off and mount a remote battery holder.
#4 3 years ago
Thanks! I will give repair a shot.
#5 3 years ago
Someone has globed solder on the edge connector contact points. That may cause problems. I would try to smooth it out.
#6 3 years ago
Basically the bottom left corner of the board will need to be cleaned up. Also remove the switches since there is likely corrosion under them.
https://pinside.com/pinball/forum/topic/terrybs-guide-to-repairing-alkaline-battery-damage
#7 3 years ago
There also appears to be a broken trace on the 5th contact from the right.
#8 3 years ago
It all looks fixable.
Make sure you read this before you begin:
https://pinside.com/pinball/forum/topic/stripping-battery-corrosion-with-a-strong-acid
$ 50.00
$ 339.00
$ 259.95
Pin Stadium Pinball Mods
$ 6.00
Rubber/Silicone
Ramp-O-Matic
Magazines/books
Just Pinball
$ 399.95
$ 1,099.00
$ 279.95
$ 85.00
$ 36.00
Ramp-O-Matic
$ 5,899.00
Nitro Pinball Shop
Various Novelties
Game Room Info Shop
$ 47.00
The MOD Couple
$ 229.99
Displays
Pappy's Pinball Palace
$ 24.00
PinWorlds
