My comment was directed at the reset issue that Ingo was describing - not a reset with the display out that you are experiencing. Apologies - pronoun issue.
Quoted from Collin:I think this game has bigger issues than I might've guessed.
It turns out fuse F3 was blown. I replaced it, and it blew immediately, and I got a strong sulfur smell.
If F3 is blowing, you have a problem with the HV circuit on the display controller which is likely why you have no display. You probably need to rebuild the HV display section.
http://www.greatplainselectronics.com/search.asp?pg=1&stext=GTLB3-HVP-KIT&sprice=&stype=&scat=
I had a conversation with Ed about the caps a short time ago - he wasn't offering them with the kit but is now. While they are likely ok at the moment, given they are 20 years old, probably best to replace them with the rest of the HV section.
You should also double check the fuse holder. The twist holders on Sys3 are notorious for going bad.
If you are going to order from Ed, you should also get the GAL for the display controller from him as well:
http://www.greatplainselectronics.com/search.asp?pg=1&stext=U8G&sprice=&stype=&scat=
You won't find anyone else selling it for less. Between the GAL and HV rebuild that should solve your display problem (unless you also have a ribbon cable problem.)
Quoted from Collin:I'm thinking when I get fuses later this week, I may try starting the game without the display connected, since that isn't working.
If you do this you have to completely disconnect the display controller otherwise if you haven't already blown U8, you will. Of course, I'm not even sure the machine will boot as I've never tried to boot a Sys3 without the display controller.
viperrwk
