My woofer in my Street Fighter 2 pin is pumping out an incredibly annoying hummmmmmming noise from the second you turn it on until it is turned off.
I can fix SOME things on a pinball machine but if it requires board repair I find someone to do it or get a new board altogehter. I'm not sure if it is a power supply issue or not. It does "work" but like I said, there is always a loud humming.
Connections appear to be ok all around so I don't think that is the issue.
If anyone thinks replacing the speaker (my prefered fix) would work let me know. I'm not a Speaker expert and am not sure if they don't just die after awhile and need replaced. I'm also not sure if this is a common problem on system 3's or not.
Could disconnecting the speaker altogether affect the machine adversely?
Any advice would be greatly appreciated! Thanks.
