(Topic ID: 213315)
Gottlieb System 3 speaker hum buzz...Calling all experts!!
By sleepygtr
5 years ago
  • 28 posts
  • 14 Pinsiders participating
  • Latest reply 1 year ago by tonyf1965
  • Topic is favorited by 18 Pinsiders
#1 5 years ago
Just got a Stargate and missed that the cabinet speaker was unplugged. Upon plugging it in (sadly, after the fellow that I bought it from was gone) I realized why it was unplugged!! A loud buzz/hum from that speaker only - speakers in the backbone sounded great! I have searched and searched the threads for potential causes and have exhausted all of them. The ground mods have been done to this game and the only thing I could find was perhaps I need to replace the MA-1772 (A5) Aux Power Supply board. Also read where many just deal with the buzz but I am certain this is louder than it should be... any other ideas?
#2 5 years ago
I've found there is a fairly complicated path for sound power on System 3 games. Mine is borderline, seems noisy when the game is idle and in attract mode...but not as noticable in gameplay mode.
At first I also thought it was restricted to the cabinet channel and replaced a number of components including amp, caps and others in the output stage. It seems the noise is also present in the backbox channels, but "masked' by the characteristics of the backbox speakers. My ground mods are also done.
Due to the way the +/- 12VDC is created, split and trucked off the aux power board means there is no simple way to power the audio amps off an external supply. I basically stopped investigating the problem at that point. It just hasn't been a priority for me.
#3 5 years ago
So you don't think replacing all the components or entirely replacing the Auxiliary Power board will help? I was thinking maybe this could be the source...
THANKS for responding
#4 5 years ago
Quoted from sleepygtr:
I'm not certain the noise is originating in aux power board in my game. There's all kinds of noise problems, and not all have the same root cause or symptoms. I'm thinking this might be a ground loop problem. If you replace your aux power board and that solves it, let us know. I'm sorry I don't have a solution at this time.
#5 5 years ago
I have a Rescue 911 with the exact same symptoms. I too was going to replace the aux power board. Please let us know if this fixes the problem for you.
3 weeks later
#6 5 years ago
I went ahead and replaced the aux power board and sadly the buzz remains. I am not sure where to look from here.
#7 5 years ago
Quoted from woodmedic:
Thanks for posting.
#8 5 years ago
Anyone think it would be worth changing the filter capacitors on the transformer? Thought it might help with the buzz.
#9 5 years ago
Measure the AC ripple. If it is less than half a volt, I wouldn't bother.
#10 5 years ago
Spectrum analyzer app pics - CBW
Game on (idle in attract mode)
Game off (background noise)
#11 5 years ago
Any updates on this? Mine has the hum also and I would love to fix it.
#12 5 years ago
I already tried the aux power supply which did not work. I ordered one of those power supplies that will do system 80 or system 3 for my genesis. I am going to put it into my R911 first just to see if it changes anything. I'll post the results.
1 month later
#13 5 years ago
The main power supply also did not fix the problem. There has to be some way of getting rid of this super annoying hum/buzz. I don't even turn this game on unless I am going to play it because the hum is so loud!
#14 5 years ago
woodmedic. did you do the ground mods? also carefully wiggle the connectors into the metal transformer plate. Sometimes these need repinned. I had a particularly bad one on the right side, after repair the hum was reduced dramatically.
#15 5 years ago
Quoted from wayout440:
I have not done the ground mods on this machine. I did wiggle the connectors on the transformer with no luck. I'll gets the mods done and post back.
#16 5 years ago
My Stargate has a slight hum also. Noticeable when you walk in the room but not while in play. I disconnected the coax from the aux sound board to the aux power supply board and shorted the audio input to the aux power supply board with a little wad of aluminum foil in the connector. Still got the hum - but not the power up "thunk". So my hum isn't from either of the sound boards. And the power-up "thunk", from what I've read on line, is due to the sound board D/As not being held in reset during power up. Back to the hum... Seemed to mainly be coming from the cabinet speaker. The cabinet speaker does not have a dedicated signal return - it runs to the center tap (CT) of the power transformer and the CT goes to the aux power supply. Not good practice to mix power and signal grounds so I ran a dedicated speaker cable form the aux power supply board to the cabinet speaker by splicing into the back box speaker signal return and the cabinet speaker output right at the cable connector going into the aux power supply board. See photo. Hum was significantly reduced but not eliminated. Can't hear it at all when you walk into the room until you're a few feet from it. Also completely masked when central air is on. Wish I had a spectrum analyzer to have more quantitative results to share.
Speaker Cable in Back Box (resized).jpgSpeaker Cable in Back Box (resized).jpgSpeaker Cable in Cabinet (resized).jpgSpeaker Cable in Cabinet (resized).jpg
#17 5 years ago
Brunsie. Thanks for posting
that's a significant amount of troueshooting. I thought my noise was cab speaker only, it sent me on a wild goose chase of replacing components only related to the cab speaker channel. Upon further analysis, the same noise is on the backbox speakers as well, just much noticeable because the speakers there have different response characteristics than the cab speaker.
Just good for thought.
#18 5 years ago
brunsie. Thanks for posting
that's a significant amount of troueshooting. I thought my noise was cab speaker only, it sent me on a wild goose chase of replacing components only related to the cab speaker channel. Upon further analysis, the same noise is on the backbox speakers as well, just much less noticeable because the speakers there have different response characteristics than the cab speaker.
1 year later
#19 4 years ago
Posting this, as it may help some one down the road. Had the very loud buzz issue on the lower speaker. This is a tricky one to diagnose as all the sounds are present, everything appears to run fine, but with that loud buzz in the lower speaker. We had even tried the new board as well. Made the mistake of assuming we must have all the voltages as we had all the sounds, could control the volume, etc. Turns out there are two separate and fused 12.6 vac inputs into the Aux power supply board (A5) . F11 was bad, not supplying 12.6vac (one of the two) to run the board properly. This causes U3 to overheat and damages it rather quickly. Replaced U3, fuse F11 and all is good. Back to the minor audio hum that all these late machines have. I suppose the same issue can happen for the upper speakers as well if F10 was bad. Hope this helps someone down the road.
#20 4 years ago
Thank you. I'll look into that.
4 weeks later
#21 3 years ago
I just got a Stargate with a loud hum coming from the 8" cabinet speaker. I rigged up a quick test for @brunsie 's fix using speaker wire. It was a huge improvement and made the speaker hum less noticeable than the DMD noise. I will be making the fix permanent next time I get a chance.
2 months later
#22 3 years ago
Quoted from Brunsie:
[quoted image][quoted image]
Having the same issue with the hum from gottlieb games and went ahead ahead and took some DB readings from inside the cabinet.
Inside I saw 56db in normal attract mode.
With the cabinet speaker disconnected it went down to 47db
Applying the @Brunsie fix the noise level is now 50db. 6 db difference and yes it is noticeable! You still hear it humming away but only when getting close. I have four gottlieb games all in the same corner of the game room and it was pretty loud. Its much better now. I did it to Stargate, Gladiators, Wipeout and Waterworld. It made a difference on all of the games, right around 5-6db each. I also have a subwoofer on each game and this helped a lot with cleaning up the sound there too.
Its easy to do and takes 15-20 mins each game. Really, it could be less I'm sure but that darn 'testing' extends things out a bit.
As a side note, 2 of the games have colordmd's (Single color) in them and it still makes a difference - Those games are just quieter than the plasma DMD games is all.
2 months later
#23 3 years ago
Glad to see this fix is working for others and that someone actually measured the improvement!
4 months later
#24 3 years ago
excellent that i find this post because i was tearing my hair out!
i had a sf2 with shorted tantalums on the main sound board and one of the 12s out , replaced them all and recapped the aux psu/amp module
now just this damned hum! was thinking about some sort of hum / low frequency rejection filter on just the base speaker, but the dedicated speaker wire
is a stroke of genius. i may yet do the filter to to shut this ahole thing up, and guess what? a cueball wizard with an even worse hum coming up.
i salute you Brunsie
- performed mod and hum is greatly reduced.
other earth modding would be beneficial even including around transformer panel mounting baseplate flange extra to line cord earth (doubling up)
and removing the silly group of white plugs and crimp on ring lugs
i also earthed the common lead on the amp module to headbox backplane (even though that is just foil on partical board)
#25 3 years ago
Does anyone have a link to the Ground Mod?
I have a "static" noise on mine through the backbox speakers with some of the music, not all music/call outs. I need to investigate it a little further still.
#26 3 years ago
I have a hum all the time on my wipeout but it’s not bad, seems on par with most older machines but every couple days when I turn it on the hum is waaay louder. Even if I turn it off and back on again it stays like that and then the next night it might be gone again for a couple days and then back.
7 months later
#27 2 years ago
I have the buzz mainly coming from the cabinet speaker in my Operation Thunder, I’m going to add a sub filter and a new sub in there that should filter out the buzz. Had the same problem in my LOTR and that fixed it.
1 year later
#28 1 year ago
Wow, hello folks. I have a Stargate. It has the hum too. When I first got it. It was pretty loud. I replaced a few cap by transformer. It did help at that time. I will try post on Stargate thread. We have some smart people here. Hope they can help.
2,200 (Firm)
Agoura Hills, CA
$ 24.00
Nordic Pinball Supply
Decals
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-system-3-speaker-hum-buzzcalling-all-experts and we tried optimising it for printing. Some page elements may have been deliberately hidden.
