I can solder darn good and have replaced many chips in my day but I have no training and always use someone else’s guide or input. I ventured out on my own and created a mess. My Sys3 Stargate sound was working great though it had a loud hum in attract mode and at times a piercing squelch on power up. Playing it was flawless. I read it may be the 5v dial adjustment that may be causing it and so I went to check what voltage it was running at. I tried to read off pin one on the smaller AUX board when I was supposed to read Pin 1 and Pin 4 off the CPU board (I learned later). Poof.
So I researched the symptoms of not booting and garbage on the screen. Thankfully there was a lot of information that fit and I ordered a U8 GAL chip on the DMD board which is finicky when things are connected powered up. I got the replacement today and it fixed and booted up. But with NO sound and a SOLID LED on the larger A6 board.
Now fiddling and measuring the correct location I can get the A6 to blink correctly if you over volt the 5v slightly to say 5.15. Then the LED on the sound board blinks and boots. Still no music but call outs like “Shoot the Pyramid” did work. Pressing the boards reset button then attempts to play the music but it’s all garbled. I then found the correct pins on the A6 board to measure the voltage and sure enough when it’s set at below 5.15 to a normal 5v it’s a SOLID LED on boot and garbled sound if you reboot the board.
So I believe the A6 board is the issue as the A20 board does the voice calls if I’m not mistaken. Maybe someone can help before I spend cash on a replacement. I have a good meter, iron, and even a logic probe but am clueless without someone’s help. I am eager to learn and have started reading some books since this really interests me as much as playing pinball.
