New! Dark mode!
(Topic ID: 276467)
Gottlieb System 3 pop bumper
By Jmckune
59 days ago
  • 4 posts
  • 3 Pinsiders participating
  • Latest reply 59 days ago by ts4z
#1 59 days ago
So I have a weird issue that I’m running into with Rescue 911 that I haven’t run into on any of my Williams games. The right pop bumper isn’t working that great. I can manually move it and it feels great and after moving manually it will work 3 or 4 times. After that I can hear the coil buzzing but the ring doesn’t move down like it should. It sounds like a mechanical issue but I’ve never seen one so weak it couldn’t pull it down. Does it sound like it just needs to be cleaned or is it something else?
#2 59 days ago
Quoted from Jmckune:
I wonder if it's a weak connection of the wires from coil to board ( every connection along the way ) and sometimes doesn't get full power ?
#3 59 days ago
Would that be the power side or ground side?
#4 59 days ago
I would disassemble it and check for all the usual stuff. I agree it sounds mechanical. I suspect you have a burr on the shaft, or a cracked yoke. It could also be a loose coil out of alignment, or a loose screw somewhere. When you move it by hand you're setting it up for success (a finger works very differently than an electromagnet), but it manages to work itself back into a bad position quickly.
If it's electrical, you can try grounding the non-banded side of the coil diode and see if it pops, and check for good voltage on the other side of the coil (jump it to one of the other pops). But I don't think it's electrical.
$ 249.00
1,750 (Firm)
Escondido, CA
$ 42.00
2,500 (Firm)
Ronkonkoma, NY
$ 29.95
$ 99.99
Pinball Pimp
Great American Pinball
$ 39.99
Bent Mods
$ 52.00
Pin Monk
Pin Stadium Pinball Mods
