Had the same issue with my Cactus Jacks. You have to remove all the GI bulbs and get your multimeter ready. Youve got either a bad lamp or a shorted socket.
First, I clipped a 7 amp thermal circuit breaker onto the GI fuse holder so I wouldn't burn through a million fuses. Then I began the tedious and disheartening task of removing all the GI lights, which meant taking off all the ramps and plastics AGAIN after I had just reassembled the freakin thing. After every 6-7 bulbs, I would power the machine back on to see if I just happened to have a bad bulb. Breaker tripped every time. After removing all the bulbs, I set my multimeter to 200ohm and clipped the leads onto the underside of one GI bulb. It read 1.2 give or take .1ish. I knew something was indeed shorted. I wiggled, poked, and prodded every single damn light socket on the playfield, looking for the resistance to change dramatically. Nada. Great. At this point, I figured Ive developed a bigger problem.
But THEN, I realized there were 5 more GI bulbs I forgot about. Two in the coin door and 3 on the dancing cactus stage behind the playfield. I took out those bulbs and on the very last socket I could possibly check (Cactus #3), I saw that one of the socket's terminals was bent forward against the body of the socket. I bent the terminal away and blammo! My GI came back on and the breaker stopped tripping. I must have bent it when I put the light cover back on during the shop job. Nonetheless I was still pissed that I disassembled the entire playfield twice to discover that the issue wasnt even on the playfield. What a pain in the ass!!!
